599 €
Travail de Thunderbike sur la FXDR...
Travail de Thunderbike sur la FXDR... Empty Travail de Thunderbike sur la FXDR...
Message par boris-jc Dim 6 Jan 2019 - 19:41
Salut à toutes et tous,
Vu sur le site de Thunderbike, leur vision du (décrié) FXDR donne à réfléchir :-)
Sacrée belle allure, je trouve !
V
https://www.hotbikeweb.com/thunderbike-customizes-2019-harley-fxdr-114
Travail de Thunderbike sur la FXDR... 01-thunderbike-fxdr-114
Travail de Thunderbike sur la FXDR... 00-thunderbike-fxdr-114-hero
While the stock tailsection is sporty, the license plate mount flanking the back tire and the debris deflector over it look like an afterthought. Thunderbike cleaned it all up by chopping the tail and dropping it to hug the bigger 260mm tire. This also moved the seat down and back, making room for a new diamond-stitched seat. Tiny LED brake light and turn signals are frenched into the tail, which also offers a much cleaner look than the stock trio of lights above.
The rear of Thunderbike’s FXDR (which they call “Destruction”) saw more than aesthetic changes. The stock rear monoshock was also swapped out for one of the company’s air ride systems, because we needed more lowering for a flat, drag bike look. The front is also 50mm lower. Parts are in production,” said Martin Mix, head of eCommerce for Thunderbike. In order to squeeze in that air ride system, the dealership had to relocate the ignition coil, but looking at it from curbside, you’d never realize all that work had been done beneath the seat.
On the front end, Thunderbike worked up a new fender and chin spoiler for the FXDR, with the spoiler more pronounced than before. On the other hand, a little farther up the fork, the Motogadget m.blaze Pin turn signals are much smaller than the stockers. The only other mod to the front is the addition of Thunderbird Satin Grips to the bars, punctuated by bar ends with the same design as the air cleaner cover.
While the stock Harley Destroyer-inspired airbox undoubtedly shovels extraordinary amounts of air into the big Milwaukee-Eight, it’s a huge honking system for a streetbike. Thunderbike’s new Oval Airbox opens up the look of the left side and feels more natural for Harley’s latest V-twin. Thunderbike’s Grand Prix staggered exhausts are routed more directly and are a bit more compact than Harley’s 2-into-1 arrangement, another move that cleaned up the bike’s pipe-side appearance.
Travail de Thunderbike sur la FXDR... 02-rear-fat-tire
Tiny LED brake light and turn signals are frenched into the tail for cleaner look. Thunderbike’s side-mount license bracket exposes the FXDR’s beefy backside for all to appreciate.
Travail de Thunderbike sur la FXDR... 03-gp-style-fender
Thunderbike cleaned up the back end by swapping in their shorter GP-style fender over the bigger 260mm tire. The new diamond-stitch seat also ends up sitting lower.
Travail de Thunderbike sur la FXDR... 04-new-chin-spoiler
A new fender and chin spoiler occupy the front end…
Travail de Thunderbike sur la FXDR... 05-oval-airbox
…while Thunderbike ditched the huge stock airbox in favor of its Oval Airbox for a more open, natural look.
Travail de Thunderbike sur la FXDR... 06-thunderbike-air-ride-system
The rear monoshock was also swapped out for a Thunderbike air ride system for a lower, more drag bike look. To make room for the air system, the ignition coil had to be relocated.
Travail de Thunderbike sur la FXDR... 07-new-fender-brackets
Of course, new fender brackets had to be designed to complement the new fender.
Travail de Thunderbike sur la FXDR... 08-grand-prix-staggered-exhaust
Thunderbike’s Grand Prix staggered exhausts (and tips) are cleaner and more compact than Harley’s 2-into-1 arrangement.
Thunderbike Harley-Davidson
boris-jc
boris-jc
Travail de Thunderbike sur la FXDR... Empty Re: Travail de Thunderbike sur la FXDR...
Message par Indy69 Dim 6 Jan 2019 - 19:47
Oui oui !!!! Nos amis Allemands sont des tueurs....  Travail de Thunderbike sur la FXDR... 709301
Un seul point "petit" point de détail.... Ticket d'entrée à 40000€  Travail de Thunderbike sur la FXDR... 710900
Indy69
Indy69
Message par bigjoe35 Dim 6 Jan 2019 - 20:19
how much? Travail de Thunderbike sur la FXDR... 710900
bigjoe35
bigjoe35
Ville et C.P : rennes
Message par Shura Dim 6 Jan 2019 - 20:30
Ouais, ben, je trouve toujours les pots moches.
Et à ce prix, vaut mieux acheter la version Screamin' Eagle 117ci.
Travail de Thunderbike sur la FXDR... 2019-h10
Message par Indy69 Dim 6 Jan 2019 - 20:42
Je ne sais plus où !? J'avais vu un échappement sympa pour le FXDR.
Indy69
Indy69
Message par Indy69 Dim 6 Jan 2019 - 20:48
Si on reste en mode 2 en 1.... Celui-là fait moins "bazooka" Travail de Thunderbike sur la FXDR... 90029
Histoire de goût.
Travail de Thunderbike sur la FXDR... Image225
Indy69
Indy69
Message par Shura Dim 6 Jan 2019 - 20:54
J'aime bien le bazooka. Travail de Thunderbike sur la FXDR... 90029 Travail de Thunderbike sur la FXDR... 700608
Message par Indy69 Dim 6 Jan 2019 - 20:58
Shura a écrit:J'aime bien le bazooka. Travail de Thunderbike sur la FXDR... 90029 Travail de Thunderbike sur la FXDR... 700608
T'as le droit !!! De toute façon il me manque 40000 balles pour en discuter sérieusement Travail de Thunderbike sur la FXDR... 111828
Indy69
Indy69
Message par Patallume Dim 6 Jan 2019 - 21:34
Plus la même moto effectivement cela change,, cette transfo est vraiment sympa  Travail de Thunderbike sur la FXDR... 90029 mais le prix est en conséquence
Patallume
Patallume
Harley-Davidson : Fat Boy 114
Message par damfx Dim 6 Jan 2019 - 22:28
Ouaip, ça me ferait presque hésiter à changer de bécane alors que je n'aimes pas du tout le look stock, manque juste un guidon plus plat, mais je pinaille, ce sont les meilleurs préparateurs à mes yeux ces petits allemands, par contre c'est vrai que ça pique au porte monnaie!
Ça serait cool qu'un membre du forum se lance pour savoir si c'est tendu à monter tout ça!
damfx
damfx
Ville et C.P : Montpellier
Harley-Davidson : Breakout
Message par lesieur Lun 7 Jan 2019 - 9:20
J adore. Travail de Thunderbike sur la FXDR... 709301 ..mais ca pique fort quand meme  Travail de Thunderbike sur la FXDR... 312952
lesieur
lesieur
Ville et C.P : auxerre
Harley-Davidson : sportglide
Message par tdzeus30 Lun 7 Jan 2019 - 12:03
Même combat que la rocker , ratée et qui renaitra en prepa puis sera dérivée en breakout, je verrais bien une évolution de ce type
Travail de Thunderbike sur la FXDR... Mini_995468tdz110
Message par Indy69 Lun 7 Jan 2019 - 12:09
tdzeus30 a écrit:Même combat que la rocker , ratée et qui renaitra en prepa puis sera dérivée en breakout, je verrais bien une évolution de ce type
Si on regarde bien, le Breakout n'est déjà pas loin... Travail de Thunderbike sur la FXDR... 90029
Indy69
Indy69
Message par tdzeus30 Lun 7 Jan 2019 - 12:15
oui ça ferait preque double emploi , après tu peux changer certaines choses
Message par Indy69 Lun 7 Jan 2019 - 12:20
tdzeus30 a écrit:oui ça ferait preque double emploi , après tu peux changer certaines choses
Oui je suis en train de bien m'amuser à modifier mon Breakout qui n'en a plus que la désignation... Travail de Thunderbike sur la FXDR... 90029
Si je dis qu'une prépa sur une base de FXDR me tenterais bien...Travail de Thunderbike sur la FXDR... 700608 J'en connais une que ne va pas être du tout d'accord Travail de Thunderbike sur la FXDR... 111828Travail de Thunderbike sur la FXDR... 807915
Indy69
Indy69
Message par tdzeus30 Lun 7 Jan 2019 - 12:26
Deux même, mamam et la Banque.....
Message par Indy69 Lun 7 Jan 2019 - 12:31
tdzeus30 a écrit:Deux même, mamam et la Banque.....
Travail de Thunderbike sur la FXDR... 807915 Hélas...
Indy69
Indy69
Message par boris-jc Lun 7 Jan 2019 - 19:44
La mob n'a que qqs mois. Attendons un peu, et je suis certain que pas mal d'autres maisons vont nous concocter des accessoires aussi sympa.
V
boris-jc
boris-jc
Message par Indy69 Lun 7 Jan 2019 - 20:04
boris-jc a écrit:La mob n'a que qqs mois. Attendons un peu, et je suis certain que pas mal d'autres maisons vont nous concocter des accessoires aussi sympa.
V
Sans aucun doute !!!
Mais Thunderbike à très bonne presse... Travail de Thunderbike sur la FXDR... 90029
Indy69
Indy69
Message par Fab of Sainté Lun 7 Jan 2019 - 21:30
Perso, je l'aime bien cette prépa. De toute façon, rarement déçu par thunderbike  Travail de Thunderbike sur la FXDR... 919984
Fab of Sainté
Fab of Sainté
Ville et C.P : 42210 Unias
Message par pierre v rod Mar 8 Jan 2019 - 13:02
Si je dis qu'une prépa sur une base de FXDR me tenterait bien...Travail de Thunderbike sur la FXDR... 700608 J'en connais une qui ne va pas être du tout d'accord Travail de Thunderbike sur la FXDR... 111828Travail de Thunderbike sur la FXDR... 807915
Allez !!! Lache-toi ! Prends du plaisir ... et en même temps, on va se régaler à voir ce que tu vas faire.
Siouplai, Msieur ! Travail de Thunderbike sur la FXDR... 977583 Travail de Thunderbike sur la FXDR... 807915
pierre v rod
pierre v rod
Ville et C.P : Pessac 33600
Message par Indy69 Mar 8 Jan 2019 - 13:19
Je vais lancer une cagnotte sur Leechi, c’est d’actualité.... Travail de Thunderbike sur la FXDR... 111828
Indy69
Indy69
Message par Simsim Mar 8 Jan 2019 - 16:45
En gros ils en ont fait un Breakout ! Travail de Thunderbike sur la FXDR... 542675
Simsim
Simsim
Message par Fab of Sainté Mar 8 Jan 2019 - 18:56
Indy69 a écrit:Je vais lancer une cagnotte sur Leechi, c’est d’actualité.... Travail de Thunderbike sur la FXDR... 111828
Travail de Thunderbike sur la FXDR... 111828, j'adore  Travail de Thunderbike sur la FXDR... 807915
Fab of Sainté
Fab of Sainté
Message par Fab of Sainté Mar 8 Jan 2019 - 18:58
Simsim a écrit:En gros ils en ont fait un Breakout ! Travail de Thunderbike sur la FXDR... 542675
Travail de Thunderbike sur la FXDR... 111828 Oui mais le breakout est quand même bien mieux  Travail de Thunderbike sur la FXDR... 919984
Fab of Sainté
Fab of Sainté
Message par floride06 Dim 13 Jan 2019 - 18:16
autant le FXDR j aime pas trop alors que la j adore
vrai qu on dirait un breakout lol
floride06
floride06
Ville et C.P : 06400
Harley-Davidson : fatboy 114
