pots road king classic origine
Comment procéder sur les chicannes pour avoir un peu plus de son Vos commentaires techniques seront les biens venus.... Amitiés JACK14
jack14- Discoverer
- Ville et C.P : Caen -14-
Harley-Davidson : softail
Re: pots road king classic origine
Utilise la fonction "Rechercher" en haut à droite de ton écran, il y a plein de solutions dedans, tu tapes "échappement" et tu devrais trouver.
giric41- Full Member
- Son Age : 76
Ville et C.P : Loir et Cher
ne touche pas a t'ai pots d'origine vas voir la http://www.passion-harley.net/le-touring-f37/pots-petits-budget-t3375.htm?highlight=pots
sinon tu vas directement la http://www.superflowmufflers.com/products.htm les max 2 sont super 140.57€ (les deux) avec le port
jean-phi- Full Member
Ville et C.P : Bonnieres -78-
Harley-Davidson : 1450 road king classic de 1999
TRUE DUALS <table id=table3 border=0 cellSpacing=0 cellPadding=0 width="100%"><tr><td><table id=table4 cellSpacing=0 cellPadding=0 width="100%"><tr><td><table id=table5 cellSpacing=0 cellPadding=0 width="100%"><tr><td width="100%">The true dual kits fit 95-06 and 07-08 FLH Touring & Road Kings. It moves 100% of rear cylinder exhaust to the left side muffler. It reduces heat to the passengers right feet and to the seat of your pants. All parts cnc bent and fixture welded for an exact fit and is guaranteed against breakage. <table id=table6 border=0 cellSpacing=0 cellPadding=0 width="100%"><tr><td><table id=table7 cellSpacing=0 cellPadding=0 width="100%"><tr><td><table id=table8 cellSpacing=0 cellPadding=0 width="100%"><tr><td width="100%"> This kit is made from 16ga heavy duty steel. It is tig welded in a precise jig to insure exact fit. The Head pipe is then coated inside and outside in a silver polish ceramic good to 1600 deg. This will greatly reduce the heat to the rider and passenger. The right side exhaust tube is a 16 gauge steel. It replaces the stock H pipe giving each cylinder its own muffler. All of your stock heat shields pipes and mufflers are used in this installation. Gaskets and a tool for truing any out of roundness on your stock pipes is included. Installation takes about 2 hours. Kit comes complete with instructions and a phone help number. </TD></TR></TABLE></TD></TR></TABLE></TD></TR></TABLE> </TD></TR></TABLE></TD></TR></TABLE></TD></TR></TABLE> |
hugh- Discoverer
Ville et C.P : 37
Harley-Davidson : Road King
giric41 a écrit:.
tu as aussi '' POTS '' ou '' POT''
enormement de lectur car beaucoup de topic de faineant qui ont tous des cas individuel
RONE- Full Member
Ville et C.P : LYON
Harley-Davidson : RK 1450
hugh a écrit:au fait, c'est quoi ces trucs, c'est bien au niveau equilibre des gaz d'echappement ?
TRUE DUALS
<table id=table6 border=0 cellSpacing=0 cellPadding=0 width="100%"><tr><td><table id=table7 cellSpacing=0 cellPadding=0 width="100%"><tr><td><table id=table8 cellSpacing=0 cellPadding=0 width="100%"><tr><td width="100%">This kit is made from 16ga heavy duty steel. It is tig welded in a precise jig to insure exact fit. The Head pipe is then coated inside and outside in a silver polish ceramic good to 1600 deg. This will greatly reduce the heat to the rider and passenger. The right side exhaust tube is a 16 gauge steel. It replaces the stock H pipe giving each cylinder its own muffler. All of your stock heat shields pipes and mufflers are used in this installation. Gaskets and a tool for truing any out of roundness on your stock pipes is included. Installation takes about 2 hours. Kit comes complete with instructions and a phone help number.
je pense que se kit sert a supprimer le tube d'équilibrage des gaz entre les tubes du cylindre avant et arriere
jack14 a écrit:Comment procéder sur les chicannes pour avoir un peu plus de son Vos commentaires techniques seront les biens venus.... Amitiés JACK14
C'est po ton probleme mon jacko vu que tes (nouveaux) pots sont vides!!!!!!
normand61- Full Member
Ville et C.P : 61200 Argentan
le Kit ci dessus ré-attribue un muffler par cylindre , modifiant le montage d'origine sur les Tourings dont l'échappement gauche est connecté sur l'échappement droit ....(remplace le "H pipe " d'origine )
ça réduirait la chauffe aussi ..........
A rapprocher du post sur les 2 en 2 ............
Matamor- Full Member
- Ville et C.P : Mâle fichu du 38 .........
» Ma Road King Classic 105
» SILENCIEUX POTS SCREAMIN EAGLE ROAD KING 2009
» MA ROAD KING APRES QLQS MODIFS
» La fin du Road King Classic
» Sono ROAD KING classic
