probleme de maps pour commander V
je vien de faire mon stage 1 enfin j'ai installer le filtre, les cornets, et le boitier power commander V mais j'ai un petit souci je trouve pas la maps qui concerne mes pots qui sont des kess tech.
Qui peut m'aider je vous donne la liste :
M15-006-000 Zero Map
M15-006-001 Stock air filter, Stock exhaust
M15-006-002 Bub 7 2 into 1 exhaust, Stock or aftermarket air filter, Stock ECM, Table 1 is front cylinder
M15-006-003 Thunderheader 2:1 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-004 Bub 7 2:2 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-005 Vance and Hines 2 into1 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-006 Rinehart 2:1 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-007 Force Motor Products Streetfighter bullet shorties, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-008 Samson Caliber 2:2 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-009 Vance & Hines Competition Series exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-010 V-Rod Muscle, Stock air filter, Stock exhaust, Table 1 is front cylinder
M15-006-011 V-Rod Muscle, Tab Performnce slip-ons, Stock or aftermarket air filter, Table 1 is front cylinder
M15-006-012 Rinehart Duals Exhaust, K&N air filter, stock ECM
M15-006-013 Cary Faas Racing slip-ons, Stock air filter
M15-006-014 TAB Performance slip-ons (turnouts without baffles), Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-015 TAB Performance slip-ons (slash cut with baffles) Stock air filter Stock ECM Table 1 is front cylinder
M15-006-016 V-Rod Muscle Tab Performance slip-ons (2.50" baffles) Stock or aftermarket air filter Table 1 is front cylinder
M15-006-017 Tab Performance Rolled End slip-opns (baffles removed) Stock or aftermarket air filter Table 1 is front cylinder
M15-006-018 Tab Performnce Rolled End slip-ons (2.25" baffles) Stock or aftermarket air filter Table 1 is front cylinder
M15-006-502 Stock air filter V&H exhaust Advanced map
Bixenté78- Full Member
- Son Age : 44
Ville et C.P : Cap d'agde
- Son Age : 44
Re: probleme de maps pour commander V
Bixenté78 a écrit:
Il faut en essayer plusieurs ( ou la géometrie est la plus proche) et faire des essais routier afin de trouver celle qui va le mieux.
sinon c'est réglage au banc
motorhead- Full Member
- Son Age : 47
Ça vaut combien un réglage au banc ?
- Son Age : 44
environ 80 roro je vient juste de commander le mien je te dit ça dans quelque jours pour le reglage
babas95810- Full Member
Ville et C.P : landes 40
Harley-Davidson : VROD NRS 09
Cool merci je surveillerai le sujet alors
- Son Age : 44
J'en ferai autant !
paco1973- Full Member
- Ville et C.P : dans le 92
Harley-Davidson : Dyna
Tu as une bonne adresse pour faire ce réglage sur banc ?babas95810 a écrit:environ 80 roro je vient juste de commander le mien je te dit ça dans quelque jours pour le reglage
- Son Age : 44
essaie déjà une cartographie ... avec du matios qui se rapproche de ce que tu as sur ton brélon.
parce que finallement , ça le fait souvent "BIEN"
après ,
si tu veux passer au banc , ça reste un choix perso, pour affiner les réglages.
le PC-5 avec le RaceTuner et autre approches à base de carto , montrent leurs limites face à un TTSMastertune , avec son mode Autoconfiguration ( quelque soit le matos monté )
donne nous des news du résultat ?
après ,
Jallie- Full Member
Merci jallie, pas de problème je donnerai des news
- Son Age : 44
pour mon VRSCR chez Godier Genou 250 roros.
http://tournay.free.fr/Banc/05.html
- Son Age : 47
je te dit quoi quand j'aurrai recu mon boitier j'ai deux adresse a voirBixenté78 a écrit:Tu as une bonne adresse pour faire ce réglage sur banc ?babas95810 a écrit:environ 80 roro je vient juste de commander le mien je te dit ça dans quelque jours pour le reglage
bon pour reponfre a ta question j'ai trouvé un cons qui prend ma brele sur un banc et reglage au petit oignons pour environ 150 e si tu veux te joindre a moi passe moi un mp je te file son tel il se trouve sur baillet en france 95 pret de chez H-D
babas95810 a écrit:bon pour reponfre a ta question j'ai trouvé un cons qui prend ma brele sur un banc et reglage au petit oignons pour environ 150 e si tu veux te joindre a moi passe moi un mp je te file son tel il se trouve sur baillet en france 95 pret de chez H-D
Bonjour voisin,
l'info m'intéresse grandement : 150 roros, c'est plus que correct
Je t'envoie un mp si tu es d'accord, pour récupérer les coordonnées.
NBSIX- Full Member
Ville et C.P : Quelque part
Une petite question. Est ce que ton concession peut programmer en boitier CDI vierge, en 125 CV version américaine quoi.
Merci d'avance
Merci d'avance
1200V4- Discoverer
Ville et C.P : VELIZY 78140
Harley-Davidson : 1340 FLHTCU
Non que les boitiers additionnel pour une carto chez hd ou tts mastertune
J'ai pu rouler un peu hier et avec ce stage 1 ca pousse vraiment fort, et elle fait un peu plus de bruit qu'avant
Jai tout de même pris rdv sur banc pour les réglages ...
- Son Age : 44
chose promise chose du je t'envoie la video de ma machine sur le banc pour info depuis le rajout du powerCV avec mauvaise maps j'étai trop riche le gars ma dit qu'il faux maitre tous a zero dans l'attente du bon reglage
Oui pour le moment j'ai mis la zéro map en attendant le passage au banc
Merci pour la vidéo
Merci pour la vidéo
- Son Age : 44
Merci babas pour la vidéo ct cool moi je vais le faire car je vien d'installer mes pots et elle a quelque ratée. Ta payer combien?
Le toxic trop beau
Le toxic trop beau
Culbuto- Interested
- Son Age : 45
Ville et C.P : Sur Ma Selle
Harley-Davidson : Harley V-Rod 2008
pour le prix cela depend du temp qu'il passe dessus pour te donner une idée il a passé 5 h sur la mienne car obligé de demonter la boite a air pour acceéder au cable du boitier Tps qui donne l'ouverture des volet d'injection donc cela ma couté un peux plus que prevu un peux plus que 200 roro
ok je vais prendre rendez vous
Culbuto- Interested
- Son Age : 45
Bon bah ça y ai ma muscle est passée au banc ce matin, elle fait 117,6 cv
Je vais essayer de mettre la petite vidéo
- Son Age : 44
Passage au banc puissance ce matin
117,6 cv à 8485tr/min 11,4 m.kg - 6739 tr/
- Son Age : 44
Bien tu sais le plus important dans l'affaire c'es le couple tu affiche 11'4 m kg bien mieux que la mienne la puissance a mois d'importance bravo content que tu as fini par trouve une solution a ton pb a bientôt sur l'Idf
Oui j'en suis content elle est bien réglée, il n'a mît qu' 1h30 et ça m'a coûter 200€.
Merci babas95810 pour la bonne adresse...
À bientôt sur les routes
- Son Age : 44
http://tournay.free.fr/Banc/05.html[/quote[/url]]motorhead a écrit:babas95810 a écrit:environ 80 roro je vient juste de commander le mien je te dit ça dans quelque jours pour le reglage
[url=http://tournay.free.fr/Banc/05.html
180€ cet hiver chez "gentlemen riders 77" a la Ferté Gaucher.
NRS 77- Qualified
Ville et C.P : Ozoir-la-Ferrière 77330
Harley-Davidson : night rod spécial 2012
Bixenté78 a écrit:Qui peut m'aider je vous donne la liste :
Bonsoir a tous
Je remet en avant ce sujet car vu que j'ai changé mon échappement kess tech par des V&H je suppose que le réglage de la map ne sera plus bonne
Donc parmi la liste ci dessus proposer par le power commander 5 laquelle correspondrait le mieux svp
- j'ai les cornets US, filtre K&N, vance & hines compétition série 2-1
- Son Age : 44
J'ai envoyé un mail à Dynojet donc pour ceux qui ont la même config que moi c'est la map : M15-006-009
- Son Age : 44
» Partage de maps pour boitier aditionnel
» Une adresse pour commander un SERT ?
» ref peinture
» Problème pour la passagère
» Problème pour installer le kit ms biketech
» ref peinture
