Le Deal du moment : -38%
99.99 €
probleme de maps pour commander V
probleme de maps pour commander V Empty probleme de maps pour commander V
Message par Bixenté78 Dim 2 Oct 2011 - 21:08
je vien de faire mon stage 1 enfin j'ai installer le filtre, les cornets, et le boitier power commander V mais j'ai un petit souci je trouve pas la maps qui concerne mes pots qui sont des kess tech.
probleme de maps pour commander V 860377 probleme de maps pour commander V 860377 Qui peut m'aider je vous donne la liste :
M15-006-000 Zero Map
M15-006-001 Stock air filter, Stock exhaust
M15-006-002 Bub 7 2 into 1 exhaust, Stock or aftermarket air filter, Stock ECM, Table 1 is front cylinder
M15-006-003 Thunderheader 2:1 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-004 Bub 7 2:2 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-005 Vance and Hines 2 into1 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-006 Rinehart 2:1 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-007 Force Motor Products Streetfighter bullet shorties, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-008 Samson Caliber 2:2 exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-009 Vance & Hines Competition Series exhaust, Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-010 V-Rod Muscle, Stock air filter, Stock exhaust, Table 1 is front cylinder
M15-006-011 V-Rod Muscle, Tab Performnce slip-ons, Stock or aftermarket air filter, Table 1 is front cylinder
M15-006-012 Rinehart Duals Exhaust, K&N air filter, stock ECM
M15-006-013 Cary Faas Racing slip-ons, Stock air filter
M15-006-014 TAB Performance slip-ons (turnouts without baffles), Stock air filter, Stock ECM, Table 1 is front cylinder
M15-006-015 TAB Performance slip-ons (slash cut with baffles) Stock air filter Stock ECM Table 1 is front cylinder
M15-006-016 V-Rod Muscle Tab Performance slip-ons (2.50" baffles) Stock or aftermarket air filter Table 1 is front cylinder
M15-006-017 Tab Performance Rolled End slip-opns (baffles removed) Stock or aftermarket air filter Table 1 is front cylinder
M15-006-018 Tab Performnce Rolled End slip-ons (2.25" baffles) Stock or aftermarket air filter Table 1 is front cylinder
M15-006-502 Stock air filter V&H exhaust Advanced map
Bixenté78
Bixenté78
Ville et C.P : Cap d'agde
probleme de maps pour commander V Empty Re: probleme de maps pour commander V
Message par Bixenté78 Mar 4 Oct 2011 - 7:24
probleme de maps pour commander V 860377 probleme de maps pour commander V 860377 probleme de maps pour commander V 860377
Bixenté78
Bixenté78
Message par motorhead Mar 4 Oct 2011 - 19:23
Bixenté78 a écrit: probleme de maps pour commander V 860377 probleme de maps pour commander V 860377 probleme de maps pour commander V 860377
Il faut en essayer plusieurs ( ou la géometrie est la plus proche) et faire des essais routier afin de trouver celle qui va le mieux.
sinon c'est réglage au banc
motorhead
motorhead
Message par Bixenté78 Mar 4 Oct 2011 - 19:54
Ça vaut combien un réglage au banc ?
Bixenté78
Bixenté78
Message par babas95810 Mar 4 Oct 2011 - 20:17
environ 80 roro probleme de maps pour commander V 90029 je vient juste de commander le mien je te dit ça dans quelque jours pour le reglage probleme de maps pour commander V 977583
babas95810
babas95810
Ville et C.P : landes 40
Harley-Davidson : VROD NRS 09
Message par Bixenté78 Mar 4 Oct 2011 - 20:23
Cool merci je surveillerai le sujet alors probleme de maps pour commander V 919984
Bixenté78
Bixenté78
Message par paco1973 Mar 4 Oct 2011 - 20:54
J'en ferai autant ! probleme de maps pour commander V 831254
paco1973
paco1973
Harley-Davidson : Dyna
Message par Bixenté78 Mar 4 Oct 2011 - 21:57
babas95810 a écrit:environ 80 roro probleme de maps pour commander V 90029 je vient juste de commander le mien je te dit ça dans quelque jours pour le reglage probleme de maps pour commander V 977583
Tu as une bonne adresse pour faire ce réglage sur banc ? probleme de maps pour commander V 85798
Bixenté78
Bixenté78
Message par Jallie Mer 5 Oct 2011 - 5:36
essaie déjà une cartographie ... avec du matios qui se rapproche de ce que tu as sur ton brélon.
parce que finallement , ça le fait souvent "BIEN" probleme de maps pour commander V 977583
après ,
si tu veux passer au banc , ça reste un choix perso, pour affiner les réglages.
le PC-5 avec le RaceTuner et autre approches à base de carto , montrent leurs limites face à un TTSMastertune , avec son mode Autoconfiguration ( quelque soit le matos monté probleme de maps pour commander V 90029 )
donne nous des news du résultat ?
Jallie
Jallie
Message par Bixenté78 Mer 5 Oct 2011 - 7:41
Merci jallie, pas de problème je donnerai des news probleme de maps pour commander V 90029
Bixenté78
Bixenté78
Message par motorhead Mer 5 Oct 2011 - 20:40
pour mon VRSCR chez Godier Genou 250 roros. probleme de maps pour commander V 831254
http://tournay.free.fr/Banc/05.html
motorhead
motorhead
Message par babas95810 Jeu 6 Oct 2011 - 13:38
je te dit quoi quand j'aurrai recu mon boitier j'ai deux adresse a voir probleme de maps pour commander V 90029
babas95810
babas95810
Message par babas95810 Sam 8 Oct 2011 - 15:25
bon pour reponfre a ta question j'ai trouvé un cons qui prend ma brele sur un banc et reglage au petit oignons pour environ 150 e si tu veux te joindre a moi passe moi un mp je te file son tel il se trouve sur baillet en france 95 pret de chez H-D probleme de maps pour commander V 977583
babas95810
babas95810
Message par NBSIX Sam 8 Oct 2011 - 16:25
babas95810 a écrit:bon pour reponfre a ta question j'ai trouvé un cons qui prend ma brele sur un banc et reglage au petit oignons pour environ 150 e si tu veux te joindre a moi passe moi un mp je te file son tel il se trouve sur baillet en france 95 pret de chez H-D probleme de maps pour commander V 977583
Bonjour voisin,
l'info m'intéresse grandement : 150 roros, c'est plus que correct probleme de maps pour commander V 919984
Je t'envoie un mp si tu es d'accord, pour récupérer les coordonnées. probleme de maps pour commander V 977583
probleme de maps pour commander V 542675
NBSIX
NBSIX
Ville et C.P : Quelque part
Harley-Davidson : Un gros garçon tout vert...
Message par 1200V4 Dim 9 Oct 2011 - 18:12
Une petite question. Est ce que ton concession peut programmer en boitier CDI vierge, en 125 CV version américaine quoi.
Merci d'avance probleme de maps pour commander V 919984
1200V4
1200V4
Ville et C.P : VELIZY 78140
Harley-Davidson : 1340 FLHTCU
Message par babas95810 Lun 10 Oct 2011 - 9:30
Non que les boitiers additionnel pour une carto chez hd ou tts mastertune
babas95810
babas95810
Message par Bixenté78 Mar 11 Oct 2011 - 10:56
J'ai pu rouler un peu hier et avec ce stage 1 ca pousse vraiment fort, et elle fait un peu plus de bruit qu'avant probleme de maps pour commander V 977583
Jai tout de même pris rdv sur banc pour les réglages ... probleme de maps pour commander V 919984
Bixenté78
Bixenté78
Message par babas95810 Mer 19 Oct 2011 - 22:31
chose promise chose du je t'envoie la video de ma machine sur le banc pour info depuis le rajout du powerCV avec mauvaise maps j'étai trop riche le gars ma dit qu'il faux maitre tous a zero dans l'attente du bon reglage
babas95810
babas95810
Message par Bixenté78 Mer 19 Oct 2011 - 22:40
Oui pour le moment j'ai mis la zéro map en attendant le passage au banc
Merci pour la vidéo probleme de maps pour commander V 919984
Bixenté78
Bixenté78
Message par Culbuto Jeu 20 Oct 2011 - 20:20
Merci babas pour la vidéo ct cool moi je vais le faire car je vien d'installer mes pots et elle a quelque ratée. Ta payer combien?
Le toxic trop beau
Culbuto
Culbuto
Ville et C.P : Sur Ma Selle
Harley-Davidson : Harley V-Rod 2008
Message par babas95810 Ven 21 Oct 2011 - 13:32
pour le prix cela depend du temp qu'il passe dessus pour te donner une idée il a passé 5 h sur la mienne car obligé de demonter la boite a air pour acceéder au cable du boitier Tps qui donne l'ouverture des volet d'injection donc cela ma couté un peux plus que prevu un peux plus que 200 roroprobleme de maps pour commander V 919984
babas95810
babas95810
Message par Culbuto Ven 21 Oct 2011 - 18:07
ok je vais prendre rendez vous
Culbuto
Culbuto
Message par Bixenté78 Sam 29 Oct 2011 - 13:08
Bon bah ça y ai ma muscle est passée au banc ce matin, elle fait 117,6 cv
Je vais essayer de mettre la petite vidéo probleme de maps pour commander V 709301
Bixenté78
Bixenté78
Message par Bixenté78 Sam 29 Oct 2011 - 19:11
Passage au banc puissance ce matin
117,6 cv à 8485tr/min 11,4 m.kg - 6739 tr/
Bixenté78
Bixenté78
Message par babas95810 Dim 30 Oct 2011 - 11:36
Bien tu sais le plus important dans l'affaire c'es le couple tu affiche 11'4 m kg bien mieux que la mienne la puissance a mois d'importance bravo content que tu as fini par trouve une solution a ton pb a bientôt sur l'Idf
babas95810
babas95810
Message par Bixenté78 Dim 30 Oct 2011 - 11:59
Oui j'en suis content elle est bien réglée, il n'a mît qu' 1h30 et ça m'a coûter 200€.
Merci babas95810 pour la bonne adresse... probleme de maps pour commander V 788660 probleme de maps pour commander V 919984
À bientôt sur les routes
Bixenté78
Bixenté78
Message par NRS 77 Mar 29 Nov 2011 - 18:13
[url=http://tournay.free.fr/Banc/05.html
http://tournay.free.fr/Banc/05.html[/quote[/url]]
180€ cet hiver chez "gentlemen riders 77" a la Ferté Gaucher.
NRS 77
NRS 77
Ville et C.P : Ozoir-la-Ferrière 77330
Harley-Davidson : night rod spécial 2012
Message par Bixenté78 Mar 1 Mai 2012 - 23:49
Bixenté78 a écrit:Qui peut m'aider je vous donne la liste :
Bonsoir a tous
Je remet en avant ce sujet car vu que j'ai changé mon échappement kess tech par des V&H je suppose que le réglage de la map ne sera plus bonne
Donc parmi la liste ci dessus proposer par le power commander 5 laquelle correspondrait le mieux svp probleme de maps pour commander V 85798
- j'ai les cornets US, filtre K&N, vance & hines compétition série 2-1
Bixenté78
Bixenté78
Message par Bixenté78 Mer 2 Mai 2012 - 19:00
J'ai envoyé un mail à Dynojet donc pour ceux qui ont la même config que moi c'est la map : M15-006-009 probleme de maps pour commander V 37298
Bixenté78
Bixenté78
